any kits out there that work like alk or meth but use E 85
stevek
I was looking to spray E 85 into upper pipe like meth system i allready have on gn, but dont see any out there does any one know of any. thanks
Sorry this isn't going to be much help, but I wouldn't bother. I would stick to what is tried and tested. Grab a alky kit from Julio at Alkycontrol some meth and be done with it. If you want to mess with E85 run some blends or 100% E85. By finding a kit that may work with E85 you are taking risks that are not cost effective. You are going to have to try a kit that isn't proven here, taking the sellers word that it will work with E85. At the end of the day your putting $3000 minimum on the line to save yourself $100 or so over the summer.
I was just thinking on spraying some with the meth kit to help cool down air temp into throttle body on hot days. I didn't want to mix in tank just because u never know what percentage it is most of the time.
I'm pretty sure you aren't going to see much of a intake temp drop spraying E85 with meth. Meth does a hell of a job reducing the intake temps. Someone please correct me if I'm wrong. You can only spray so much before you start to get puddling.
hello; I know nothing about spraying. IMO you could spray any thing you want but it will be like starting over in your cars performance. If it was me I'd let someone experiment and maybe come up with a new product. But you could give it a shot. Turn your boost level down and play with your scan tools and see what you see.
have fun and post your experiments
IBBY
IBBY
You can't spray what you want. E85 is no good for all Meth pumps that I know of. And if E85 is no good for it other things must be bad for it too.
thanks for the feedback ill stick with my SMC meth kit it seems to be working good so far, it does drop air temp pretty good ,thanks for your help
hello; I think you made a smart choice. But is the add on meth kit the same as the seventh injector that still or use to be sold? With it there was no other fuel needed other than what's in the tank and I don't know if a extra pump was needed.
IBBY
IBBY
The alky kit is designed to suppress knock not to supplement the fuel system....You add just enough alky to keep away knock..Meaning you also don't want to pull fuel and try to use the alky to substitute for it...
At the same time though it seems like alky certainly adds fuel to the equation. If you run a car with race gas to a certain boost level, then run 93 and alky, your IDC will most likely be lower on the alky run. While you may not be using alky to add fuel, at the end of the day it still does.
