turbo96max
- Jun 6, 2007
So I tested the stock Garrett .63 housing machined for the P wheel . I wanted to test for better boost response.
I had my wastegate venting back into the downpipe. Never really ran over 15 psi in the past but I had the car ready for more boost now and cranked it up. I found that as soon as the boost got above 15-16 psi the turbo would intermittently surge or give a quick short sneeze under wot. the boost gauge also would dance around +- 4 - 5 psi.
I tried a harder spring, same thing just changed a bit depending on the spring, tried a soft spring with boost to the top of the wg, same thing. I figured the wastegate could be causing more back pressure and decided to dump it to atmosphere. The surge got better but still would get an irratic boost gauge and slight surge here and there.
I ended up putting the garrett 82 housing back in and the gauge holds 25-26 psi true without any turbo surge.
Is it likely that too much back pressure causes these symptoms?
Would a open downpipe help?
What do the turbo gurus think about the .63 housings? Will I have this issue when I get my new turbo 6266 with the precision .63 housing? Is there something else I need to look at ?
Chime in if you can, appreciate the help
pt 70 h
casv front mount
small 206 cam
1 in intake spacer
Tial 44 wastegate
TH dp
ATR dual 2.5 exhaust
sd chip 120s e85
old wastegate routing initial controller rjc
dump tube w knob controller
pt 70 h
casv front mount
small 206 cam
1 in intake spacer
Tial 44 wastegate
TH dp
sd chip 120s e85
