John Larkin
Sublime Master of Turbology
- May 25, 2001
This is probably a tired question or statement but I am told any wideband will read E85 on the same scale as gasoline and you don't need an E85 specific wideband. Apparently all widebands work off "Lambda" or a centralized stoic ratio and read above or below that point based on inputs. So whether you are using E85 or gasoline, 14.7 is stoic. Then you tune the car the same depending on what your car likes or what others have found to work?
I ask because I want to buy a WB and want one that matches the rest of my gauges rather than having an ecletic array. Form and function can work together.
