Or any cam for that matter....
I have been chasing this stutter/miss for a little while and it has baffled me.
At anywhere from 15 psi to 22 psi my car will run 115 mph. in the 1/4 with the Speedpro showing only 1 to 3 % correction. But usually when I hit 2nd gear with higher boost or at the top of second gear with lower boost the car starts to miss erratically. Not like a secondary ignition miss but like cylinders are dropping out.
I've tried to check fuel pressure, and it doesn't seem to be dropping off. Yet if it starts to stutter and I let out and get back into it the miss is gone for a second or two and then returns. In those couple of seconds the car will pull harder than it was.
Now for the other bit of info..... Today, I left work and got the car up to temp (5 mins of driving) and then blasted off and recorded the run. It pulled harder and faster than it did at the track Friday at only 15 psi. Then I went ahead and tried it a couple of more times tonight, recording each, and the miss/stutter came back the hotter the car and the longer I ran the car.
Could this be Valve Float? What does Valve float feel like? What about fuel related? I got the cam from The GSCA as a kit with valvesprings cam chain and pushrods a couple of years ago. This is the first time I've had everything "right" and able to take it to the track.
I can send some of the LOG files to anyone if they think that it'll help. Thanks!!
Pat
Pat
