SignUp Now!I have years ago. The bushings have limited life and the stock rod isnt a piece that is worth spending extra on. If you have a good piston and a good tune you shouldnt have problems grabbing the pins anyway. For a serious race only engine that is making 150+hp per hole its probably worth it but then you wouldnt be using stock rods anyway.
When they say to "bush" the small end what does that mean exactly?? Thanks!
The rod is bored on the small end and a bronze bushing is installed in it and honed to size. You can slighlty alter the length of the rod by doing this to achieve better quench and you avoid the chance of a piston grabbing the pin and ripping out the bottom of the piston since the pin is floating in both wrist pin bores.
Better choice would be a set of K1 rods. MUCH stronger, and affordable.
Buy ARP bolts, polish the beams, shot peen them, resize them, bush the small end, and you still have a stock rod that is inferior to an out of the box K1 rod.
This is correct. I always assume everyone already has a set of high performance pistons. Silly meAnd to add the that, the piston MUST have some sort of pin retention device, such as Spirolocks, ect. You can't use TRW or stock pistons with full floating pins (bushed rods)
