Anyone handy near Hanover PA?
the stock rim is only 7" wide (178mm) which is not ideal for a 275 tire thats 275 mm section width 11.2" but many have done it
mickey thompson recommends min 7.5 rim max 9.5" rim on their 275 but it will go with no rub issues unless your car is really slammed
I had some 275/50/15s on stock T wheels and they worked. Rubbed a little but not bad. BFG drag radials.
I agree with Paul, the tire will "fit" on the rim but the sidewalls will be too much "squeezed" in. It will make the tire wear unevenly, more in the middle than on the edges. Frankly, 7" rim is less than ideal and not wide enough... but if you got to have stock appearing wheels, try www.gbodyparts.com ...they can sell you stock appearing GN wheels in any width you want.
Good luck,
Claude.;)
