pmoore4321
- Jan 10, 2010
I have decided to go with a roller cam after reading the horror stories of wiped lobes on flat tappets. I will be using Champion iron heads with the following "bolt-ons" that were on the car when I got it. The only mods to the shortblock will be TRW forged pistons.
I guess I am going to go with the Full Throttle cam package. Which profile would be best? I know the TC is a big factor, but I don't know what the stall is on the PTC 10"? This car will see very little, if any, track time and I just want to cruise on weekends. Thanks for any help. Also, anyone have any horsepower numbers on a setup like this? I come from an SBC background and can't wrap my head around the V6 numbers.
I want to get this engine back in the car before the Texas summer kicks in!
choices:
206/210 .516/.516 110 L/S
Good stock replacement and driver cam 2800 stall
210/215 .516/.516 110 L/S
Hot street, Most popular unit good manners and power 3000+stall
setup:
Champion irons
Precision T49 Turbo
Applied Technologies Cold air intake
Applied Technologies Valve cover breather kit
Terry Houston 3" downpipe
2 1/2" Stainless Pitbull exhaust
Precision Turbo Stretched Intercooler (13"x17.25"x3")
Red Armstrong XP Fuel Pump
42# fuel injectors 621031 (set of 6)
Kirban Billet Adjustable Fuel regulator 6547
TurboTweak chip
Red Armstrong Voltage Booster
RaceTronix fuel pump wiring harness w/body ground kit
PTC torque converter 10" 2800
Scanmaster 2.1
Aluminum radiator
Ajustable wastegate actuator
Bilstein B46-0929-HO rear shocks (pair)
Bilstein BE3-D150-HO front shocks (pair)
Air Lift rear air springs
Kirban under hood brace kit 6744
Kirban rear seat frame brace 1586
Kirban front frame braces 6564
Hotchkis 1201 upper control arms (pair)
Hotchkis 1301 lower control arms (pair)
choices:
setup:
Champion irons
Precision T49 Turbo
TurboTweak chip
Scanmaster 2.1
Aluminum radiator
