Anyone know something about the 93 t/a prom/ecm?
usetaboost
SAY CAR RAMROD!!
My car has a code 26, which is quad driver module 1. I have no scan tool to command solenoids, relays, etc. so I was thinking why not get an aftermarket chip. I have already had to gut the cat and pull the air pump cause they were no good. THis has been done for quite sometime with no ill affect so I know it isn't from this. I'm sure a simple hypertech will not solve this problem because the emissions isn't deleted off. Anyone know where I can get a better tune with no emissions for a decent price. I wonder if eric could do one????? Maybe cottons?
You need to find out WHY the quad driver failed. A common cause would be a shorted fuel injector or a shorted wire. If you replace or repair your ECM without fixing the cause, you might end up with the same problem again. Food for thought.
