Anyone launched with BFG 325/50/15 Dot's?
GNVYUS 1
TurboBuick.Com Supporter!
I am about to purchase these really soon and would like to know what boost psi, tire psi and 60ft times were with these on your GN.
I realize these are bigger than the common 275/60 most run but I had a custom fender flare job done so I could fit these. I am sure a few have put these on and just let them stick out a as they are 27.8x12.8x15.
I don't know any GN's with them, but at some Mustang races they have a drag radial class where they use the 325s and 315s. I don't know what they launch at or tire psi but they pull the wheels and run mid to hi 8s. Have fun with them.
Gotta ???
Will these tires stick out pretty far with a 15x10 with 41/2 B.S. Man these may be what I want. They would look killer. What did you go to the GNX flares an so surely you didn't just put them on the back!!! Did you??
Gotta ???
I have 15x10's with a 295 on it and am about 3/8th from rubbing the frame.
With the 295's on the car, the tires buldge over .8 on each side. The 325's buldge 1.4 on each side. So you would need a 1/2 inch spacer just so they would not rub the frame.
Then, add on that your really adding on all the new tire width to the offset of the rim. You would need a flare that is at least 1.2 inches wider than the stocker.
I do not have the cheap GNX flares. I paid big bucks to have a
1 1/4 metal flare worked in so that it looked like part of the car. It costs way more but I plan on keeping this car for a long long time and wanted to run major fatties on the car for more intimidation to those supras around town.
A wheelie is plenty of traction for me. That reply will answer my question, thanks.
If you have a picture of this flare job I would love to see it. I am a body man and planned on notching the frame on my car eventually, but maybe your way would work better.
Zak
