Sam Colalillo
low 9's w/ a 109
All prices listed are plus shipping.
$165.00 Set of 6 turbo tweak 80Lb injectors (269 new)
These were installed two years ago on engine I built. Customer recently had me pull them out went bigger when I installed the FAST XFI system. They have less than 1500 miles on them and worked flawlessly when I pulled them out last month.
https://www.turbotweakstore.com/SearchResults.asp?Cat=6
$55.00 Turbo tweak Classic chip v5.7 (119 new)
This is the chip that drove the injectors I am selling.
Tuned for a 62/62 turbo 200R4 trans stock gear running e85 w 80 lb/hr injectors
$175.00 Scanmaster G for turbo Buick (259 new)
I removed this from the car I recently installed an XFI into. It works perfectly and easy way to get plenty of data out the stock ecm.
https://www.turbotweakstore.com/ProductDetails.asp?ProductCode=1007-Buick-G-black
$25.00 3” inlet K&N air filter w provision hole for air temp sensor
$115 two two gauge a pillar pod with autometer 5343 digital tachometer and built in shift light mounted to a pillar plastic. No gauges in the holes
https://www.summitracing.com/parts/atm-5343/overview/
$30 Automoeter Ultra lite 4303 30 psi boost gauge
$370 each (I have two of these assemblies and the price is not for the pair ) Aeromotive fuel pump assemblies each one comes with at least 12” of -12 hose, -12 fitting on each end of the hose. 12307 pre filter, fittings to get filter onto pump, a100 fuel pump and a -10 outlet fitting. These fittings are expensive. I had both of these pumps mounted under my car and they work great! Second one came on at 9 psi triggered by the XFI.
more information on above parts.
Aeromotive 12307 100 micron filter (129.40) new
https://www.summitracing.com/parts/aei-12304
Aeromotive a100 fuel pump (411.99 new)
$250 set of 6 precision turbo 120 lb/hr injectors
These were cleaned and flowed by precision turbo after I pulled them from my car and have not installed after having them checked.
$225 Competition cams roller lifters. These roller lifters have less than 500 miles on them. They were in a stroker engine I built for a car. I later bought that car and replaced the camshaft with a much larger one and converted it to solid roller lifters.
$50 Trend performance push rods for hydraulic roller lifter and scorpion rockers
8.700 long .080 wall thickness
$50 Trend performance push rods for solid roller lifters & scorpion roller rockers on champion heads with a .040 head gasket
9.25 long .105 wall thickness
$200 Crane Cams shielded solid roller lifters part number 62518-12
$45 Wiper motor from 87 grand national
$20 200r4 pressure valve cable
pictures of above parts coming soon.
