anyone order floor pans from shermanparts?
G NASTY
i'm in a bind trying to order there type or the one from goodmark. anyone use the sherman pans? anyone have any promo codes for sherman?
Yeah that would be awesome! I was going to order from eBay because the shipping was 50$ cheeper then direct from Sherman. But I also need both door lower skins and and door bottoms. I found a promo code for 20% off for sherman but it's expired. The order is over 600 without shipping so it's a big chunk.
No sorry I forgot shipping. Shipping was $80ish. One big piece not two halves. And I'm pretty sure it's coated with something. The metal was black and not perfectly smooth so I'm assuming so
Part # gmk-4035-500-78s
I used the ones from Sherman a long time ago. As long as the quality is the same as it was back ten years ago....they are very nice. You will have to use the seat braces from the stock floors though.
i ordered mine from gbody, pretty sure they are Sherman from the part number, but was cheaper to get them thru gbody, did mine last fall...quality was good, but you do have to reuse your old seat mounts
i was going to order from g body but the shipping was crazy. shipping on ebay is 100 for both sides. from sherman shipping is 150 for both sides. shipping from g body was like 240 if i remember right.
Normal shipping on 2 pans is $144.00. What I have done for several customer in the past is cut the pans in half where the seat brace over laps to hide the weld. We can normally ship them like that for $70 for 1 pan & about an extra $15-20 for both pans.
We have to put an average shipping price. We have actually lost $ shipping west of the Rockies.
whitecobra98 you are correct that we do use Sherman parts. We also use Good mark as well.
I ordered floor pans from Gbody parts as well and installed them about 4 months ago. Didn't have a problem with the pans. They fit great.
You will have to re-use the "saddle" type seat mounts that fit over the cross member along the door sills. Mine were rusted out in spots and I had to repair them. Nobody sells those mounts new as far as I know so don't throw them out. I guess you could get a rust free set from somebody out of a donor car. The gbody seat mount kit only includes new mounts that go on either side of the trans tunnel.
i was more than happy with the sherman pieces, wasn't complaining at all, and was about to reply to the shipping price too....i got both from you and it was only an extra 15-20 for the second..very pleased
Ok, as of 1 minute ago, the owners son says no promo codes, for now. Each pan (drivers and passenger side) is 231 dollars each, with a total shipping cost of 252 dollars shipping, to area code 11221.
Thanks man. I appreciate the call. I'm going to call them after. I found an active promo code "FB3" if anyone also needs it. It's 15% off total till sept 30. They quoted me 150 shipping on the phone so Ill see what's up. Thanks again
