Chris, I use a 15 row made by Kendall. The ground clearance is the same as where the stock scoop would be. Now mine uses the stock neck length (with a big neck on it but located in the stock position), so I envision you having to make a custom neck with a really tight bend in it to gain reasonable ground clearance if you use two full cores. Either that or you will just use a big neck welded directly to the top of the endtank which should work; the top of the core is going to be much higher than stock regardless if this will be a street car. A custom uppipe should be no biggie since there seems to be room to do that. Plan on losing the front swaybar too or minimum relocating it forward. It could all work with the right engineering. One note: I remember Kendall saying that the joint where you attach the core together is a bich to get to seal with the TIG (as in hard to get in there). Good luck.
