Right!On a side note , that long block only cost me $3500 from Mike Dobkins .
And the aluminum heads the op is looking at will cost more than that alone
SignUp Now!Right!On a side note , that long block only cost me $3500 from Mike Dobkins .
Are you saying the ported aluninum heads with the stroker and 64-66 turbo with the right cam won't combo? What are your thoughts on the champion iron heads versus the alunimums?Right!
And the aluminum heads the op is looking at will cost more than that alone![]()
Are you on a stock crank and rods? I didn’t see them mentioned in your sigPorted iron's will do anything you need them to do and be much cheaper . Champion irons are CNC ported , nothing a good head porter can't do . The ported irons will not be your bottle neck and flow more than enough for 700hp . My car in the video has all of the parts in my signature and can be a hand full on the street . Ask the guy on a 600 crotch rocket that I smoked in a 50 - 130 mph roll race by 5 car lengths ....... and I gave him the hit !! Watched him in the rearview banging gears !
The 64 turbo cannot max out a champion ported iron head.Are you saying the ported aluninum heads with the stroker and 64-66 turbo with the right cam won't combo? What are your thoughts on the champion iron heads versus the alunimums?
Stock crank & rods . I believe the weak link is the block . I know of one motor with stock crank & rods that have been at over 800hp for an entire season , with lots of races and driven regularly .Are you on a stock crank and rods? I didn’t see them mentioned in your sig
All you would be doing is spending thousands of dollars that are not needed.
I have been trying to keep money in your pocket this entire thread![]()
OK. So how does this combo sound to you? Ported Champion iron heads, stock ported intake. GN1 stroker kit, 109 block with billet main caps, 114/114 cam or 115/120 cam, 28-30 pounds of boost with the 64/66 turbo. and David Husek transmission and converter.The 64 turbo cannot max out a champion ported iron head.
Looking like a strong build as long as you put good pistons in itOK. So how does this combo sound to you? Ported Champion iron heads, stock ported intake. GN1 stroker kit, 109 block with billet main caps, 114/114 cam or 115/120 cam, 28-30 pounds of boost with the 64/66 turbo. and David Husek transmission and converter.
what valve springs are in this seat pressure range for these cars? Several posts on this forum where PAC1201s recommended for roller cams on these cars. IIRC, PAC 1201s are in the 130-150 lb seat pressure range, 450 lb/in. rate. Some builders claim the PAC1201's spring pressure drops following break-in. Other stated options: Comp941s, K-750, PAC1218 or 1203 - set-up and application dependent. i don't recall seat pressure at 200 lb, tho would be based on set-upSpring pressures I'd be looking for more than 200lb on the seat with duals or possibly looking at beehives.
Have a look at PAC1222X. 180lb@1.8" and just over 200lb @ 1.75"what valve springs are in this seat pressure range for these cars? Several posts on this forum where PAC1201s recommended for roller cams on these cars. IIRC, PAC 1201s are in the 130-150 lb seat pressure range, 450 lb/in. rate. Some builders claim the PAC1201's spring pressure drops following break-in. Other stated options: Comp941s, K-750, PAC1218 or 1203 - set-up and application dependent. i don't recall seat pressure at 200 lb, tho would be based on set-up
Definitely do that. Dave is the man and a 6466 is a better turbo for a true 9 sec full weight street car. Yes a 62 has gone 9s but that’s not easy.Thanks for all the feedback. You guys have convinced me to run the 64/66 turbo with a David Husek transmission and converter. Now the issue is finding a camshaft.
I usually dont really recommend girdles( and I have nothing against them)because I prefer caps and@Mr.Spool
At what HP level do you recommend a girdle if one stays out of KR. I'm referring to a 109 block. TIA
Thanks I just called and they said their parts will not work with the Danny B setup.Check T/A Performance. They had cams and parts a while back for the early nose conversions.
TIMINATOR
