If you go back to what I said I never mentioned I wanted to run a certain ET or build a car to meet a desired ET/MPH. What I said was Patrick at Precision says the 62-62 turbo is more than enough turbo to get into the 9's if someone wanted that. I only said that because you said the 62-62 wasn't capable of doing that. That's all I meant by that. If my car sees the track it will be to make one pass here or there if I'm at the track for a car show. By no means is this car meant to be competitive on the track or to be a track car. I raced Mod Motor Mustangs for 15 years and I was the first Mod Motor car into the 7's besides John Mihovetz. I been there and done that already. I know what a car takes to run 9's and deep into the 8's even. I don't want to do this with this car as its too nice. It's very a very clean car, absolutely spotless inside and out with only 38K miles. I don't want a roll cage or drag suspension in it as this car will be handed down to my 14 year old son someday and if he ever wants to put it back to stock and sell it for big money some day.
With that said I am all ears about converters. thanks
Ok
Never said the 62 isn't capable of running 9s
I said you wont do that
And neither will most with a buick v6 guys
Because in reality it's really not enough turbo for a full weight combo.
I dont care who runs it and has gone 9s with it.
Heres the cheatsheat=
To 98% of the cars with 6262 turbos it's really a solid 10 sec fast spooling turbo on a full weight gn car on what I would consider moderate boost ranges below 30
There are plenty of guys even in this thread that run bigger better turbos and haven't got there and there is a reason for that.
I went 10s on a 58mm cast turbo(49) decades ago
And yet I dont recommend that turbo for a 10sec car.
The reason= it's really hard to do and
Much easier to run 9s with a bigger turbo.
6262 turbo for 650 rwhp well I've seen some magical things on a dyno on different platforms
when it comes to dynos your goal of 650rwhp again is most likely not going happen.
I posted what you needed earlier and if your serious it's there.
It's a alot of change.
See 650rwhp or 9 sec is the same power
The weight changes the et
Sounds like you have a nice car and want to pass it down and already had fast stuff and dont want to turn it into a race car.
So dont
Many in this thread have given you good advice
If you want a good lockup converter contact dave husek.
You will also be needing a trans when you hunt for more power he is a master at the 200.
