TIMINATOR
- Jan 26, 2020
We tried....
TIMM
TIMM
SignUp Now!I might have another source. Keeping fingers crossed.We tried....
TIMM
TA VRL 100 isn't equivalent to "Danny B" set-up? I heard it was, but could be misinfo... I'm looking at the TA instruction sheet right now for their camshaft thrust bracket...machine cam thrust surface OD = 1.3775" x 0.340"Thanks I just called and they said their parts will not work with the Danny B setup.
Sorry for this newbee question but what is TA VRL 100?TA VRL 100 isn't equivalent to "Danny B" set-up? I heard it was, but could be misinfo... I'm looking at the TA instruction sheet right now for their camshaft thrust bracket...machine cam thrust surface OD = 1.3775" x 0.340"
Ta performance catalogSorry for this newbee question but what is TA VRL 100?
Or a phone ca
As I mentioned here Feedback about roller camshaftsTa performance catalog
Or a phone call
Thank you. I will call them again and ask them specifically about this part. I appreciate the feedback.or kit with thrust plate and gears is VRL 101
See page 65 in TA catalog
Yuck!Everyone is right about this 10 inch PTC converter. I ran the car yesterday. 17% slippage going through the traps at 5650 rpms.
Had the MT 255/60R/15 on the car. Absolutely horrible, converter is going in the trash where it belongs.
What did it run?Everyone is right about this 10 inch PTC converter. I ran the car yesterday. 17% slippage going through the traps at 5650 rpms.
12.05 at 112.5 with 28 psi thru the traps at 5560. I couldn’t leave under boost with these tires. Beat 60 foot was 185 leaving at 2000. Tune was spot on. Data logger shows huge stretch in 3rd gear and it just stays at 5400.What did it run?
28lbs on a stock motor should be running roughly 11.20@118 with a 1.5-1.60 60ft.12.05 at 112.5 with 28 psi thru the traps at 5560. I couldn’t leave under boost with these tires. Beat 60 foot was 185 leaving at 2000. Tune was spot on. Data logger shows huge stretch in 3rd gear and it just stays at 5400.
Yeap I am painfully aware. 16% slippage aint going to get it done. Yes the transmission was built. I am taking both out and going with Dave's transmission and converter.28lbs on a stock motor should be running roughly 11.20@118 with a 1.5-1.60 60ft.
Is your trans built as well?
Sounds good. I just talked to Dave and ordered the converter.Real world result with Daves 3021 convertor with a locals TR. Stock block...alky...26 PSI. 11.4 at 117. I worked the slip rate right around 12 percent. I ran a couple of LU's locked but they didn't last long. I went to a NL and never looked back.
