Anyone up North use Block heaters?
Little6pack
Just wonder if anyone in northern part of country uses block, water or dipstick heater in the winter?
I have heard the dipstick heaters burn the oil?
My Dad used to use a dipstick heater in a '61 Chevy he used to have. Other than people w/ diesel engines, I know of no one around here using them.
Later,
Steve.
I have a block heater but its wrpped around the whole car,
It called a heated garage stays 75 all winter:D
For my winter vehicle (1997 Bonneville). I use a block heater whenever the temperature falls below -10C (15F) over night which here is pretty much late December to early March. The car starts much easier, oil pressure rises right away, you get heat sooner, the ECM adds less fuel since the engine starts warmer, what's not to like. I also use a timer and have it come on a little before 5:00AM.
It was -32C (-24 F) 2 days ago. At home the car started great, after work sitting all by itself the starter turned it over way slower. It was so cold the seat foam was like a rock until it sucked some heat out of my butt and it warmed up.
A block heater does a better job than an oil heater since there is so much more mass. Heat the oil up all you want it won't be the same as heating up the coolant. I have heard of inline pump style heater that go in a heater hose and circulate coolant around. Its much easier to install a block heater.
For fun on a clear day last winter I took the Buick out at -20C. Its like not having a turbo the spool was instantaneous. The wheels spun instantly on the frozen pavement.
we use block heaters on ALL of our bulk gas dispensing vehicles that go out, they're 429 Fords and a single Kenworth diesel. The vehicles are reliable, and start up readily. Far as it goes, I wouldn't see any danger to the oil from a block heater due to the boiling point of the coolant being a limiting factor. I'd definitely reccomend one if you're gonna run your ride in cold weather, hell anything 30 or so and below we turn on the block heaters as a precautionary measure. It'll probalby extend engine life due to having warmer oil on tap during startup. Can't hurt.
If your coolant is set for -30 and the car is sitting in your garage, I think you don't really need a block heater. I have never used one and never got a cracked block sitting over winter. Maybe for your yard ornaments though:D
it will be 0° in the morning and -2° friday when i get up at 445 to head out for work-
ive been driving my 87 turbo limited, im thinking of getting a timer in the house and a lower rad hose heater for it-
next week its supposed to be 60:rolleyes:
BW
