Anyone use muffler inserts?
Never used them on a car but they make a huge difference on V-twin bikes. I had a Bigdog with open exhaust, added some inserts that are similar and helped with the sharpness of the exhaust note without making it sound weak. I also dynoed it both ways and with picked up 4 ftlbs but lost 3hp.
Hey Bo.
Thats why I went to 4" catback. I wanted the benefits of dump but withOUT the noise. Plus you can hear the engine better at wot. Years back I was told to uncap the dump... It helps a lot and sounds badass. Well, I did and it sounded hideous and ridiculous.
There is drone with 4" exhaust but they sound great at wot.
Mufflex makes a 3.5" catback with Spintech, Magnaflow Straight thru or Flowmaster to choose from. 3" DP - 3.5" catback with a straight thru muff might be the ticket.
I have a 3'' stainless cat back from SLP which is a through design and it is very nice, but it I need to reduce the weight of the car because I have to cage it. I know this whole SLP unit is at least 40 lbs I could shave off if the insert sounded decent.
I'll probably just buy one and see what it sounds like.
I have used the perforated cone in a couple of vehicles and have great results. I put a Gibson exhaust on my 496 gas truck and absolutely HATED it. The drone was unbearable. It was loud and completely irratating at any RPM. I almost yanked it off. I decided to try one of the cone thingys and it made a world of difference. It sounds good now and the drone is almost completely gone. I also used one in my diesel pusher motorhome. I needed some extra space and the stock muffler was 18" by 2.5 feet. I replaced it with a much smaller muffler and added the cone. The difference between stock and the much more aggressive muffler was only slight. A great product.
I bought the one from Summit. $99 and free shipping. Should be here this weekend.
im going to try the dynatech in the tails of my atr dual 3"
15 ea spiral discs 11" long
Just got my Insert with collector. There is NO WAY I am putting this on my car. The insert dia. is only 1.75'' from a 3'' collector. This is nothing but a big restriction and will rob horsepower. I was thinking from the pic that the dia, was way bigger....almost like a through design. This is going back.
