TR Custom Parts
Mark Hueffman - Owner
- May 25, 2001
SignUp Now!View attachment 250205 No burned fingers Earl! Put a bolt thru the brace and laid it flat on the belt sander and whittled away. Pushed down on it with a square of padding I had laying around. Dunked in water when it got too hot. Too bad something so simple wasn't the right dimensions, at least to me anyway.
Has anyone ever just made a solid steel rocker shaft? If not, why?
Earl, have there been any thoughts of a push in round slug that is pre drilled to just stiffen the stock shaft? It maybe still too weak around the bolt hole that way though.
Last summer when going roller, I went with the thicker ta shaft and the 4 rjc braces. Seems to be doing alright on a very mild mild roller *knocks on wood*.I think TA still makes the thicker shafts. I bought a set back when I was putting together my motor. That was 3 or 4 years ago. Check out the comparison. I sold my set of 4 RJC braces and went this way.
