Anyones car?
GMHTP...
They did the readers evaluation of the upcoming and prototype GM cars in that issue. Several of those people were from here. If it was in GMHTP, it did not get a feature - my car was the only full feature (and cover) for that issue.
I'll sell you mine for $19,500 - or race him for pink slips. :D
Originally posted by matt87
whys he got to be on drugs?
He forgot to state the mileage.Usually important when asking top dollar for a car.:confused:
TA-49 Turbo $675
Kenne Bell AFPR $110
Red Armstrong XP Fuel Pump/Caspers Hotwire $145
Charged Air Stretched Intercooler $600
Rebuilt Trans with 10vane pump, hard Stator and
Sunshell, 2800 Stall Loosened Stock Converter) $1400
Accel DFI Installed and Tuned By Turbo People of
Hastings NY $1200
Stock Exhaust Manifolds with a Custom Pass side with a
Turbonetics Racegate and incar Boost controller. (custom Welds for atmosphere dump. $1200
009 (42.5 pound) Injectors $325
RJC Racing Power Plate $65
Bowling Green Customs 3" Downpipe (Stainless, w/EGT
Bung Tap) $200
3" Exhaust from the Downpipe to the tips including
Stainless UltraFlo's $300
Hollow 3" Cat.
Tompka Cold Air Induction Kit $200
South Side Lift Bars, Upper and Lower $225
Pinion Snubber $20
Airlift Airbags (both sides) $85
ATR 1 3/8" Sway Bar $179
Driveshaft Loop $22
160 Thermostat $10
Torque Strap $25
Frame Braces $110
Back Seat Braces $65
Vacuum Brakes with Comp Cams Reserve Can $150
B&M Stacked Plate Design Trans Cooler in parallel with
stock in radiator unit $65
TB Blockoff
Dual Fans (2370 CFM) $125
High Strength Turbonetics hose Clamps $30
Bilstein Stocks All Front/Rear $300
PTE Turbo Saver $185
$8016
Gauges...
Kenne Bell Hood Mounted FP Gauge $125
(triple Gauge pod) $45
VDO Tach on top/Caspers Volt changer $165
Caspers Knock Middle $65
VDO Boost bottom $35
Dual Console Holder $115 with below Gauges
VDO Oil
VDO Water Temp.
$550
Mechanical
A/C System Changed (bad compressor) and now works
great still using the R-12. $225
New Upper control arms Left/Right with NEW
balljoints $250 + Alignment
New Delco Battery (2 months ago) $85
Fresh Radiator (10k miles on it) $285
Exhaust Hanger changed last weekend $65
New Headliner End of Season $175
New Coil Pack $65
New Washer/Coolant Tanks (november last year) $35
New Front tires not even 100 miles on them yet $240
NEW Hood Pad last Season $85
Neoprene Rear/Front Main Seal $225 installed
New Motor Mounts Last Season (before Torque Strap) $75 Installed
New Inner/Outer Front Wheel Bearings when i changed
Brakes Last Season total $100 with parts for brakes
New Sealed Power Pushrods $35
All New Relays on Drivers side (3 fan relays including
Fan Delay Relay) $100
New O2 Sensor Last Season $65
New Cam Sensor when i did the timing chain $140
$2250
Extra Set of Centerline Wheels $150 Each = $600
Extra Built Motor 10/10 Crank, Steel Main Caps, Roller Chain, Kenne Bell Cam, JE's .030 with Coating, Fully Ported Heads W/Stainless Valves, Champion Intake, 70mm Accufab TB/Plenum, fully assembled!!
$4k+ (motor and rims)
Custom Show Quality Stereo System,
3 Amplifiers 2 NOS SAS Bazooka Tubes (they look like
NOS Bottles) Concert Sound all speakers upgraded,
Alpine Headunit with Remote Control. $2500 with installation
$2500
Dress Up
Chrome Turbo Shield $120
Chrome MAF Pipe $90
Chrome Plenum $125
Chrome Vacuum Lines $70
Chrome Upper Radiator Support $195
Chrome Charcoal Can cover $ 24
Chrome Blower Cover $25
Chrome Up-Pipe 3" $90 Custom Chromed a Black 3" unit
Chrome Master Cylinder Cover $12
Chrome Throttle Bracket $40
Chrome Washer Tank Cover $15
Chrome Coolant Tank Cover $15
Chrome Power Steering Bracket $40
Chrome Engine Brackets $100 (3 pieces)
Chrome Relay Bracket Pass side $70
Chrome Hood Hinges $175
Chrome Hood Brackets $55
Chrome Hood Safety Latch $40
Chrome Drivers Side Intercooler Bracket $55
Chrome Hood Latch $65
Chrome Hood Spring $30
Chrome Striker Plate $63
Chrome Hood Shock Covers $27
Chrome Drivers Side Relay Cover $25
Chrome EGR Cover $24
Chrome Fuel Rail $120
Chrome Oil and Trand Tubes $100
Chrome Fender Braces $75
Chrome Cruise Bracket $65
Chrome Belt Tensioner $125
Chrome EGR Solenoid Cover $18
Chrome Cruise Control Cover $20
Chrome MAF Cover $22
Chrome Alternator (145amp) $195
Chrome A/C Accumulator Bracket $45
Chrome Power Steering Cap $18
Chrome Manifold Coolant Lines $70
Chrome Battery Hold Down Insert $13
Billet Oil Fill/Breather $32
Breather Blockoff Pass Side $16
Billet Turbo Inlet $50
Chrome Differential Shield $65
Billet Aluminum Overdrive Waterpump Pulley $75
Chrome Engine Wire Harness $21
Chrome A/C Compressor Cover $40
Chrome Wire Loom (alot) aswell as Black Loom $50
Custom Trunk Carpet Kit with Embroidery $200
Chrome Under Hood Light housing $40
M&A Valve Covers $200 (powdercoated)
Low Mileage Seats Front/Rear $600
$3865
Original Window Sticker and Clean Carfax also goes
with the vehicle. Also Full GM Documentation from GM
Canada which gives each of the cars Factory Options,
Build Date, Ship Date, Dealer Info and more....
Total $21,118
+ $ 6,250 what i paid for the car
Total $ 27,431
Plus All the Shipping costs of above listed items, AND install charges for some things, And the Timing Chain, and all parts related, and dont forget CORES on alot of the stuff above, which puts this car right at the $30k mark!!
If you guys think i am asking so much what do you think i should sell it for 12K 14K?? or f*ck it free??
I dont mind people picking apart my car, but it has every bit of what i listed and MORE!! Been in Several Parades, the TurboBuick.com Calendar, and a local Calendar, tons of trophies, and last placed 1st in the NY Equal to world of wheels @ the Nassau Coliseum
Am i so wrong to want to get part of my $$ back?? and if it doesnt sell who cares? I was only going to buy a $28k GNX i found
NASHTY Yes I AM IN GMHTP next to my car and so is ARTIE the one who KNOWS EXACTLY whos car it is in the local paper!! Yours is the feature but mine is still in it..
As for drugs, no no drugs here just the knowledge of what i have into the car and not trying to get the 28k its currently insured for.
As for Mileage if your interested in buying call me you all obviously have the #
And Frankly I am a lil upset that so-called friends would try to bash a friends car (ARTIE And ED) they both know its mine, but want to see what kind of thread they can instigate??
Mike,
You have a nice car and you should ask what you want for it. Hey, you might get lucky and find someone with the cash in hand who wants only your car.
Why didn't you post it on this board that you support?
I know guys will tear it apart like now.
We both invested alot money to get it to run low 11s and would have to ask the same price to get some of it back.
About the drug thing: Former President Clinton and Mayor Bloomberg both smokes dope.
Good luck, i hope you get the GNX,
Artie
Bashing?
There will be no bashing here!
Mike,
I didn't bash you car.
I only listed it.
Ed did not bash you car.
He only noted you must be on drugs. For what reason, I don't know.
Don't get bent out of shape. It happens alot when someone trys to sell their car I noticed. I read it all the time. I also posted my disapproval on the "cars for sale" how everyone who is trying to sell their car gets criticized from wrong grill to wrong clamps.
Artie
Mike, It would be nice to get back all monies invested in a car. But in the real world it will never happen. I know your car, history, performance and who it came from and it's still a very nice car. I've been around Turbo Buicks since the beginning. You may get lucky and get your price in the cars buyers market paper. But if you posted it here most will know in detail the real value. My guess would be $14,000. Also Mike you seem to be the first one to knock down or discredit any car or parts for sale on here or on E-bay. Go back and review your archives. One of the cars you dragged through the mud here on the board was a friend of mine. I'm not mad and still call you a friend. Just lighten up on others trying to sell cars or parts now that you know how it feels.....;)
Ed/Artie I do not mind my car being pulled through the mud as i stated earlier, it was posted by artie "Anyone's Car" He specifically KNEW who the car belonged to. As for Deicrediting a car yes i discredit a car that i look at to be misrepresented. Or an ebay item Way over Priced but never e-mail or try to bash a board member for what they are asking for a vehicle, its usually a Car Dealer MISREPRESENTING their Vehicles. As for my car do i think i will get the $$? i dont know, but i wont part with the listed items which some have not even made it into the car. Who was your friends car that you say i discredited? please link me i am interested i knowing. I dont go in the For Sale Section to look and pick on any car in there.
(here is a link to every post i made in cars for sale) http://www.turbobuick.com/forums/se...d=392491&sortby=lastpost&sortorder=descending
Here is a listing of each post i have regarding somthing you might say i am bashing/any ebay auctions i replied about
http://www.turbobuick.com/forums/showthread.php?s=&threadid=75298 (dealer selling a NON GNX as a GNX)
http://www.turbobuick.com/forums/showthread.php?s=&threadid=76828 (ebay auction for Ruggles Scanmeter which i credited it as being such not discredited)
http://www.turbobuick.com/forums/showthread.php?s=&threadid=76429 (a dealer listing in Hemmings for a non GN)
http://www.turbobuick.com/forums/showthread.php?s=&threadid=74768 (someone selling a Kenne Bell IC that was mangled)
http://www.turbobuick.com/forums/showthread.php?s=&threadid=74323 (posting about a Wrecked GN on ebay)
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2404487704&category=6137 (WE4 Being Sold as a GN on ebay)
http://www.turbobuick.com/forums/showthread.php?s=&threadid=67997 (me commenting on a radio in a post someone else made)
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=6137&item=1876836485 (ebay GNX that i asked a question about the A/C Accumulator)
http://www.turbobuick.com/forums/showthread.php?s=&threadid=67421 (misrepresented TTA on EBAY from a dealer)
http://www.turbobuick.com/forums/showthread.php?s=&threadid=67009 (others ripping i just stated no door tags)
http://www.turbobuick.com/forums/showthread.php?s=&threadid=66707 (others talking about a car i just linked to 2 other posts)
http://www.turbobuick.com/forums/showthread.php?s=&threadid=66398 (pointed out incorrectly routed plug wires)
http://www.turbobuick.com/forums/showthread.php?s=&threadid=65734 (ebay post wondering if its a GN or WE4)
Ed i dont see an above post which i believe i ripped a part, please PM or e-mail me a link to the post you say i am being so negative to a friends car. I am interested.
and i cant find any posts i am ripping/abusing/bashing anyone trying to sell parts... please inform me. I am light about it but when its said i am taking drugs to think the value of my vehicle is 2/3rd or less what i have into it and should ask alot less then i do feel i need to state my reasons
Mike, No need for me to go any further on this post it will only get worse.. I made my point and hope you get the money you are looking for. As for my friend he sold the car and I really don't want to post his name or the new owner here. I will discuss it in person if you like over a beer. I'll buy:cool:
No problem Ed, maybe tonight @ bellmore..... Depending on the weather...
