anything to add? or take off?
Cleaner13
The Cleaner
ok guys this is a combo I plan I using after I get the spring cleaning finished off
is there anything I should add or take off of this list
I am looking for a fast street car (nothing rediculous) I dont want to buy a new turbo, no engine work, and I do not want to run race fuel since I am not blessed financially (IM only 19)
big mouth air intake
the walbro fuel pump and hotwire kit
Kirbans fuel pressure regulator
air bags, pinion snubber, air bag spacers, sway bar
ATR 3" downpipe
hooker exhaust
thrasher 92 chip
scan tool (obviously)
RJC power plate
"parts I am thinking about"
headers
70MM plenum
alum driveshaft
thanks alot guys your always a big help
Carl
your basic list looks pretty good, here is what I would change:
downpipe:
Terry Houston or Mease Performance, the ATR stuff has a history of sticking wastegate pucks
Adj fuel pressure regulator:
Check out the billet rebuildable unit from CAS or Accufab
Pinion snubber:
forget about it & do the s10 brake pistons and a control arm boxing kit from HRPartNStuff instead
Add a Thrasher 100 chip and run a xylene homebrew when ready for some street or track action, my car ran solid mid 12's with a similar combo. :)
Be sure to get yourself a good set of guages:
30/30 boost, fuel pressure, oil pressure & knock are what I consider essential.
As for the maybe stuff on your list
headers: unless your stockers are in terrible shape you don't NEED headers until deep into the 10's. Whatever you decide, STAY AWAY from the Hooker headers!!! Their long tube design promotes a ton of lag in anything slower than low 11's!
70mm plenum: again not needed just go with one of Jay Jackson's ported stock units and a power plate & you'll be set
Alummy driveshaft: unless your stocker is in bad shape not needed so spend the ~$350 on an alky system & have your car ready for action at all times. :)
Doug C.
Forget the "thinking about" parts and pinion snubber. Spend it on good rear suspension arms or have yours boxed (cheaper).
downpipe:
Pinion snubber:
Doug C.
I AGREE!!!!!! the alky is a must to turn up the boost ,assuming you have a adjustable wastegate.
Agreed. Also forget about the air bag spacers. You probably won't need the ATR swaybar but it will make somewhat of a difference. Do the lower body bushings and GNX bushing as well as all of the front braces.
Also, go with a Terry Houston downpipe, or if you are on a tight budget go with a Kirban type downpipe with a ported elbow, it is alot cheaper. I ran this into the 11.7's and probably could've gotten more out of it.
Not worth your money
Sounds good
I dont have a buick but I know alot of fast cars that run just an airbag. Since your not going to run racegas and will have a 13 second car, why waste your money??
ATR 3" downpipe
Save your money, Your stock downpipe WILL NOT be a restriction till your into the 11s and again since your not running racegas you will have a 13 second car so save your money.
hooker exhaust
You need some kind of exhaust, the stock one is horrible so go for it.
thrasher 92 chip
I love that chip but you have to tune the car to make it work. If your planning on setting the boost at 17bs and thats it then you might want to look into another chip with more timing. I was able to run 19-20psi with the Thrasher chip and no knock on 94 octane. It made more power (track tested) than a Reds 93 at 17 psi. The reds had more timing and I could only run 17-17.5 psi before it started knocking. So like I said, If your planning to run 17psi get something with more timing. More Boost and lower timing will make more power than high timing and low boost.
Get a Scanmaster, that way you can always look at whats going on. No need for Turbolink or Directscan since it sounds like your not really going to be racing.
RJC power plate
Never tried it, its like 65 bucks right? Make your own decison...
headers
70MM plenum
alum driveshaft
Thats all a big complete waste of money there...
Things you should add to your list.
Valve Springs
Boost Gauge
Nitto Drag Radials
Don't forget to do a spring cleaning.
Carl
No Problem ;)
Locking up the stock D5 converter with a lock up switch will also make a difference and it's cheap. I saw 2 tenths and 2 mph gains with just this simple cheap little mod. Also, the bigger Duttweiler modified neck for the stock intercooler Poston sells for $75 is a nice cheap mod which could give you about 20hp (about 2 tenths and 2 mph). If you don't want to run race gas and want to see 12's the SMC alky kit is a must and it's only about $320. With 15-17lbs of boost with the stock turbo you will probably be running mid to low 13's at best if the car is in good running condition. Definately make sure you change the valve springs like TTA89 mentioned! If you don't buy the alky kit spending $60 for some race gas will be the best and cheapest mod:D
ok this is just a for instance
but say I upgraded the turbo
would it be possible to see 12s without the race fuel?
also what turbo should I go with?
thanks again guys
Carl
Alky. Kit, Duttweiler neck or a V4, and sticky tires!
Crank the boost on pump gas with alky.! Can you drive? That will determine your track times the most in MHO. :)
At the track or on the way up throw in some Sunoco GT100 unleaded for safety and kill the cat. and get a good exhaust.
Just my .02 it ain't all that easy I learned but damm it sure was fun! :D
thanks again guys
Carl
When you upgrade the turbo you generally dont see that big of a difference in power till you reach the 20psi mark and your not going to get there without racegas.
Running these cars on pumpgas is like running a V8 car with 2 plug wires removed. They don't run on pumpgas!!!
If you dont want to run racegas or alky you might want to think about selling the car and getting something that runs on pumpgas. You'll probably go faster than you will in a buick on pumpgas.
