Approx. how much gain w/ te44, thdp, & V4?
ross87t
I was wondering what the approximate gain would be(1/4 mile & mph), if I went w/ a te44 turbo, thdp, and CAS V4 intercooler. I will also be replacing my valve springs w/ comp 980's soon.
Current setup is in my sig.
Ross
I ran my TE-44, THDP, 36#, 2800 stall combo to a best of 11.57 @ 114.5. I would say the car ran most consistently in the low 11.70's @ 112-113. This was using a stock intercooler with a duttweiler neck. Not sure how much more a V4 will give you over a big neck stocker that is properly cooled between runs.
HTH
My guess is that you would prolly pick up somewhere around .7 tenths in the 1/4 and 5 mph. Of course this is a guess......tuning, car, traction, boost and all that other stuff comes into play! You'll definately like the change......best way to sum it up!
They will really help that 5.0. :D
The V4 and 44 turbo will work well at 24 psi. on alky.
You should reach your goals with good tires. :)
