SignUp Now!The 109 block is used on every 1986-1988 G-body with the 3.8. I still see plenty of them in the boneyards. Yep just drill the drain hole and you're ready. The only model of G-body you wont find a 109 in are the Chevys. An easy way to tell if it is a 109 block without getting dirty is to peek in through the wheelhouse opening. All 109 blocks have drain plugs on the side of the block and you can see them through the wheelhouse opening. Just look by the motor mounts.
No higher nickel content. They are not proven stronger. They all have the same meat in he webbing area which is not much. Go for the heaviest casting you can find. Stage 1 and 2 have a different alloy and thicker mains. I just threw away 4 blocks of which 3 were easily useable. They are very common and cheap in junk yards.the 109 blocks have a higher nickle content in the castings I think? Which should make them stronger.
