B
bry593
Guest
I noticed that the TV valve plunger is larger on a CZ valve body. This has me wondering if the shift valves are larger too. If this is true, dropping a CZ or BR governor into a non-perf 2004R should move shift points completely out of the RPM range.
Questions:
1. Why is the TV valve plunger larger?
2. How come GM eventually put a spring under the TV valve?
3. Are the shift valves larger in a perf VB? If so, what would happen if a CZ or BR governor was used in conjunction with a non-performance valve body?
By the way, I picked up a copy of "Principles of Operation" and have developed a pretty good idea of the function of each valve and spring, although the section on planetaries hasn't quite stuck yet....
Many thanks,
Bry
Questions:
Many thanks,
Bry
