SignUp Now!u can have them all. send me youre adressSend me 4 and I'll measure the pressure at installed height. I need more than one to get a good average on the spring tester testing 4 inner/outer at once then just the stock outer. Is say this could be of advantage on some application
That is a great pic. What manual is that out of? I haven't seen it before. I bet there is more info in whatever that came out of. Great find.Is this helpful? This mod helped eliminate an apply timing issue I was having on the 2-3 shift there was a bind at low rpm shift pretty much gone now. http://photoshare.shaw.ca/image/a/4/f/119991/transgopage010-0.jpg?rev=1
Did you get a chance to check these out?That's from the HD2A instructions. I have a copy in fact I have the whole kit. I can measure the springs next week.
The hd2 A kit is quite a bit different than the old HD2 kit, this one has specific instructions for hot rod valve bodies vs low perf stuff, comes with a billet servo and boost valves. Still lacks some things though
Are you at work?thanks for the reminder. remind me again tomorrow when im at work lol
