The relief valve spring is orange 2.2" (18 coils).
The pump slide spring is 1.7" (11 coils).
The pressure reg spring is pink 1.8" (12 coils)
The clutch converter valve uses two yellow springs 1.1" (10 coils) inner and 1.0" (7 coils) outer
The TV boost valve is .551" dia.
See attached photo of the springs used and the valves. Is this a good combination of parts. Any comments or suggestions on these items would be appreciated.
I am in the process of a rebuild on the trans and I am now on to the pump. Thanks
paul
paul
