Ok, so I had the great idea to replace the pins and bushing in the driver's door to fix the sag. Well, I can't for the life of me get it back high enough! I've loosened all 12 bolts on both sides of the hinges and pulled up as hard as I could and it won't get high enough! It's worse than when I started
I even go two teenagers down the street from me to come and help try to get it high enough - no luck! All my buddies have moved away and so I have no one else to help me. I'm about ready to take it to a body shop and pay the bazillion dollars it will cost for them to spend the 10 minutes to get it right! ARG! Anyone have any secrets to get it high enough? I used the jackto help support it and then tried to lift up the door slightly w/ it but it just lifts the body.
