What is the correct way to wire the nitrous control on the FAST unit to engage when the transbrake has been released. Anyone have a wiring diagram?? Thank you.
5 pin bosch relay. 2 to the coil, one feed, 2 switched. The "at rest" feed is connected to his NOS arm. The switched feed is connected to nothing. The relay is merely tapped into his t-brake trigger.
On burnout/pass/shutdown, the relay is enabling NOS. NOS will be activated by normal means. Linkage switch, pushbutton on steering wheel whatever. With the t-brake applied, the NOS enable is off. And the linkage switch or steering wheel switch is not completeing a circuit.
If I sent it right via command line, a quickie wiring diagram should be at:
Ok, well, substitute the TPS for the battery feed to the relay. in other words, the contacts in the relay that close, will connect the TPS signal wire. So the wire in my schematic that goes from the battery to the relay, substitute the TPS for the battery, and instead of the switches listed for NOS arm and NOS activate, send THAT wire to the NOS control box that activates the system.
Point of all this is, you want to open the circuit and NOT arm/activate the NOS with the t-brake on, and the relay is the easiest way I can think of for opening that circuit.
I called and talked to Lance. He talked so quick, I had to sit down and think about it for awhile. I was able to come up with this out of what he said. Thanks everyone for the help.
