Astro roof quality?
davidf
While I'm on my long quest for the perfect GN {ok ok, their all perfect:redface:} I've never considered anything other than a hard top. I'm not a fan of mid/late 80's GM t-top build quality. However I do find an occasional cherry GN with astroroof. 1987 Buick Regal Grand National, $24,995 - Cars.com Are these problematic? The car will see no track time. Thank you.
I like mine & only thing I need to do is replace outer rubber seal. Been saying that 5 years but as long as the drain tubes are clean it wont leak.
If the OP doesn't mind a small digression, what method do you use to keep the drain tubes cleared?
For the original post, the Wife's Regal ('87, in black, but with a V8) has the astro roof and there haven't been any issues with it. It is actually nice. Even when closed it gives a much more open feeling to the car. No leaks except when she leaves it open overnight and it rains :eek:
And during the nice weather she always has the astro roof up or open. So it does get quite a bit of use.
RemoveBeforeFlight
Mine works just fine--replaced outer seal about 5-years ago as it was leaking when I purchased it...But then, my power antenna still works just fine too! I did acquire an Astroroof "inner frame" seal too (before discontinuance of mfre)--for possible future need/use...
Mine works ggggrrrreat..
Though the owner befor me had a new headliner installed & they reversed the switch or the hookups. When i press fwd it opens.
I even have a complete spare setup stored away.
Thanks for the replies guys. Being a hard top guy, many of the cleanest ones I've stumbled on to have astro roofs.
RemoveBeforeFlight
blow compressed air in there.
I LOVE MY ASTROROOF CARS. t top cars are junk had 8 t top roofs i pulled apart were rotted under the metal plates. probably the only way to get a unrotted t top car around here is to get a low mileage garage queen
My two leak a bit. :p
One didn't start leaking until a rear end collision at 20 mph however. :eek:
The other one only drips on you when you take corners too fast in the snow or rain. :biggrin:
