ATR down pipe ?
ikle
I have a ATR DP with internal waste gate the swing arm shaft has side to side play as well as up and down play I can literally move the swing arm shaft roughly 1/16" up and down and 1mm side to side is this normal. Thanks,ikle.
I have...
the external w/g on my ATR, but it sounds like it may be getting a little sloppy. However, if you are not having boost control problems you should be able to run it until a convenient time for upgrades etc. If it's causing boost control problems, maybe the puck is too small to cover the bypass port w/the additional play, then it's time to repair it.
