It would help to enlarge the wastegate port on the side of the turbo. Install it and watch for boost creep. If it starts to creep at high RPM, then the port is too small. You can enlarge the port on the car. Just grind the port larger and radius the inside to allow better flow, then start it up and the grindings will make their way out the exhaust. I've done this many times.
