ATR Ram Air
Kevin Turch
Senior Member
Hello, Needed some help here, i have a atr ram air but have yet to install it, I currently have a 9' k&n, and was wondering if im going to need to buy a shorter MAF pipe, in order for the ATR canister to fit, i believe the filter that came with the kit is 12' or 14'
Kevin
Is your charcoal canister relocated under the fender well with the vacuum ball? this is the only way the ATR ram air with the 14" K&N will fit. Once you relocate the canister, you have an extra 6 inchs or so in length, so if you haven't done this yet, after you do, your current MAF pipe should work.
Yes, i did that along time ago to get my 9 to fit, it just seems my current maf pipe is alittle to long, ill have to see, might just be my eyes :)
