Feb 24, 2002 #1 N NCTTA Warp6 is in my Jet Wash Joined May 26, 2001 Messages 61 Would the back of the intake(under the coil pack) be a good location for the sensor...no negative effect? How would this compair the in the uppipe?
Feb 25, 2002 #2 N norbs Classic fast, XFI, SPortsman & MS3 programming Joined May 25, 2001 Messages 6,212 The best place is in the up pipe, since in the intake the temperatures tend to read higher, due to heat from the aluminium itself. The speed density fuel calculation is based on ATS temperature, so the more accurate you can be , would be better.
