Okay...Has everyone received their pics of my setup!??!?!?
BuickTV6, has anyone resent them to you???
IMO, there isn't enough room to use the 86/7 lower intake hot-air style...The entry point is too far to the front of the intake and would end up running the front cylinders way lean...There isn't a good enough airflow path to the rear two cyls if you run it that way...Not only that, it is a plumbing nightmare and all the little mods would drive you nuts...I was able to do it because I had access to a machine shop full of tools and equipment that would cost someone who would have to go to a machine shop a whole lot of money to have stuff made...Especially with the trial fittings and reworks that I had to do...Then, if you plan on running the 84/5 accessories on the front of the motor, everything has to be tweaked and relocated to get stuff to clear the 87 intake with the 84/5 accessories...Nothing fits like it used to and it's a PITA to work on...
Oh BTW, that wierd plenum is my custom upper plenum
And the 87 lower intake still sits up a little too high for my liking, but to change that would require major machining and I just don't have the time or the access to the machinery needed to do that at my leisure(which I might add, I have a lot of right now
) The inlet tube on the plenum is about as far forward as I could go and that was barely enough room to allow the turbo to still fit on top of the motor...There are a lot of little mods that I had to do that I can't even remember half of them all right now...
Hate to try to discourage some of you, but it may look easy, but all the little things would nickel and dime you to death if you had to have a machine shop set up and machine stuff for ya...Depending on your area, for a hour's setup time and machining would likely run you about $50/hr today...That's even if the machine shop would touch a custom one-off job...Setup time and time spent with the customer while figuring out "EXACTLY" what they need runs into a lot of money...Then if the part don't fit and dimensions need to be changed, that's just more time and money down the drain...If you tell them what you want and they make it and it don't fit, it's not their problem...They made it the way you wanted it...Now if you need something a little different, then you gotta pay for it...
Don't know what else to say...but Good luck if you try it...
