Attn:Mark/Bruce
ITSAV6
It's my Granny's car!
I'll be home today as well as tues&wed and you can call me about my 2nd gear starts. 229-468-0875 If you get my machine,leave a message and I will call you back.
Thanks,
Doug Tatum
too much tv setting causing high pressure in governor circuit?governor and forward clutch bias the same passage.
chris
I hope that is all it is. It's a PTS trans and Mark was supposed to get Bruce to call me about it. I set the tv with factory procedure then backed off 2 clicks. After it warms up it stops doing it.
Maybe Cali fell into ocean? :D
P.S.: Thought you were gonna send me one of your recalibration for my other 2004R? I sent you an email right after you offered it to me,do I need to call?
send me your address,but if you like pts i understand you dont have to use mine.
Sorry Doug, no ill intent
But, Mark Y has been in the hospital for the last 2weeeks. Congenital heart failure and an infected and collasped lung. We were scared for a bit there, but he should recover. Real slow tho.
I have been running like crazy trying to cover him and do my other 3 jobs. I have not even been around the board.
You are not being ignored, I didn't even know this post was here till this morning. I am sorry and will get back to you, or give me a shout when you can.
I am selling out of all my Buick stuff.
I will be putting ads up in the for sale section here shortly.
ALL MUST GO!
Life has changed again, time to roll with the times.
Bruce
WE4
Hate to hear that!
I hope all is well with Mark! I noticed that ya'll haven't been around lately. I'll call Monday morn. Send Mark well wishes.
Doug
ITSAV6
Did you find out what was causing your second gear starts? What did you have to change?
Brian
85 monte
I have got to a psi check at idle. Needs to be below 130psi@idle or it will second gear start-after it warms up the fluid is thinner and it stops. Bruce told me this on the phone monday. Gonna try to get to it tomorrow,but I am remodeling our house and landscaping too.:eek:
2nd gear starts?
Did this get fixed? Would love to know so I can see why mine is still doing it?
Brian
yes
Now with tv adjusted where it don't give 2nd gear starts my full throttle shifts are a little low(4200). Now I gotta pull my engine back out for rebuild (wiped cam lobe after 4000 miles and filings got in bearings-now i am adding forged pistons and billet caps and balancing). I probably have 3-400 miles on tranny now since nov!
