ATTN: Oil return grommet.. new source!
TType84
cookin with propane
Stop paying $6.00 + shipping and waiting a week.
Browsed the help section today and found a perfect replacement.
HELP! #42323
Works perfect... listed as a PCV grommet for "GM"
Originally posted by buickpower
excellent, thanks!
sorry, i should note, you will have to shave a thiny bit off the outside perimeter with a razor blade, takes all of 5 minutes
I've been using a "help" grommet for a while now... it's got a little smaller inner diameter, so the tube won't go through right. But if you install it into the intake, and take a drill bit to the inside, it hogs out nicely. Not sure if it's the same one you're using, but it works.
