Chris told me that you are the master guru of GM.
I'm having a little trouble that I was hoping you might be able to help me with...
I have a 92 Blazer S10 4.3L Vortech W.
I mistakenly cut the power wire to the ABS. I was trying to find the power to the fuel pump to hook up a kill switch. Anyhooz, I reattached the wire but the abs light still comes on.
I hooked up Chris' snap-on scan tool to pull/clear the codes but there were none. We ran a ABS diagnostic and still no codes. I disconnected the negative terminal on the battery to try and reset the ECU and the light still comes on. We couldn't find the ABS fuse however all the fuses we found checked out. I know the ABS is working. I can feel the pedal slightly pulsating when I brake.
Any ideas?
Thanks in advance!
Nesto
Any ideas?
Thanks in advance!
Nesto
