AVC VDO GNX style instrument cluster - sender units?
paradigm
Does anyone know if the VDO GNX style instrument cluster use factory sender units for the oil pressure and water temperature gauges?
I have an 87 GN but with a 5.3 gen 3 LS motor in it (yes I know its not right but thats what the car came with) that I am looking to install these VDO gauges onto. Trying to figure out the wiring and which sending units to get the gauge cluster to work with.
You’ll need the correct VDO specific sensors for both of these gauges .
Do you know which sender part numbers are needed? I emailed VDO but I am waiting on an e-mail back. I also noticed you had a copy of the installation manual but I cannot access the link anymore, would you be able to send me a copy please? My email is paradigm905@hotmail.com
BTW I used to live near Mississauga growing up (Brampton) but I am now in Long Island NY.
Sorry, I’m not much help on the senders.
Any VDO dealer or repair shop should be able to supply those .
The gauges used in the AVC dash are VDO Cockpit gauges .
Thanks Dave for the instructions I received them.
As for the sending units I am going with are:
360003 for the 80 PSI oil pressure sending unit
For the water temp I am still figuring out which to go with.
I purchased the Water Temp_ VDO 323-421 Temperature Sender
And
Oil psi_ VDO Pressure Sender 80 PSI - 1/8-27 NPTF
VDO 360-003 Pressure Sender
