Lynn D. Brown
- Oct 24, 2004
On my '87 GN, I'm running into a bumpsteer problem with the B spindles, or maybe they are F Body, which I think they R the same except for bolt circle. My bump steer is pretty bad w this combo, so I tried the taller lower ball joint from SCNC (Mark Savitske). Well now because of the wider track of the B/F spindles, one of my front tires is hitting the outside of the wheel well. I reduced the tire size from 245-50 to 225-60, but it still hits on bumps, and it's even tearing up the new tires. I also have Hotchkis Upper A's.
So, I was looking at the 2 tall spindle kits from SCNC that are actually off of a C5 Corvette. These tall spindles (same height as B/F) have the narrower track like the G body short spindles to solve my hitting problem and supposedly the geometry will also solve the bumpsteer problem. Pretty damed expensive, though. But they require 13" Corvette rotors, however, so that means 17" wheels and tires. So now the total bill really gets out of hand.
I already have 12" 1LE brakes, and would like to reuse those and avoid the new wheel / tire expense, but apparently they don't fit the Corvette spindles. Don't know if any of U guys have any other alternatives to get rid of this bumpsteer ?
I did just get another tidbit from Hotchkis which I didn't know about. D Oliver said that U have to replace the Tie Rod ends with some other kind when U do the B/F spindle conversion. I didn't know that when I did the conversion 10 yrs ago. I have to ask him what TR ends I need. Anyone know about this ?
