B&M pro stick shifter
larry33kc
I have a B&M pro stick shifter in my car and I can't get it adjusted right is there anyone with instructions or know how that can help I need it bad. Thanks
No problem. The shifter cable is a PITA to get just right. It is alot easier with two people and a 12 pack. 6 under the car and 6 for the person in the car. I started by trying to get Park and 1st, then tweaking the cable position forward or backward in the cable mount. Then using the small adjustments on the threaded cable end to get the others in position. Make sure you remove the cable from the lever on each gear to make positive that it is dead on. It can be a 2 hour ordeal...Mine was a Pro Ratchet but I think they are the same. Good luck. By the way, I removed mine and went back to stock.
Bryan
I know I have been under there many times with no luck. I might need someone just to keep me from going insane.
