correction
I installed the kit new about a year ago with a th400 and that car went back to stock , kidglock grabbed up the package and it came with the shifter but we already had done the same shifter in his car so here it is .
the console and chrome cover are unused as well as all those brackets for other makes (didnt need to use them for a gn install )
the shifter and the cable has low hours with the th400 and is in perfect shape with the standard chrome quicksilver ball ,
it works with any trans like the 2004r or three speed like the th400/th350 and works with forward or reverse valvebody
all the parts are there on the cable to to just bolt it right up ready to go on a th400 ,
for a 2004r , remove the cross pin at shifter (which will give you one more gear pull for four gears ),flip around the cable mount bracket and use the other hole in the selector bracket
the instructions are included and were never opened
i install a lot of these and it will fit under the GN console if you remove the small factory bracket on the floor
I run one in my 86 with a th400 rmvb and have one for my 87 with 2004r otherwise it would be staying here
