turbov6joe
Signal 1 J-12
- May 22, 2002
Just wanted to pass on my findings in reference to additional tranny coolers on the TTA. Last night I installed a B&M stacked plate tranny cooler (largest unit they sell) in union with my OE tranny cooler. I noticed that the tranny fluid temps dropped significantly (not sure of the exact amount of degrees, as my temp gauge doesn't have numbers on all lines), to be exact, the temp dropped 2 lines under the normal running temp of around
190*-200*(in the 90+* heat). I'm guessing that the drop was around 50*-70*! On the T brake, the temps NEVER got over 200*, and that's saying something if you know how much heat a T brake adds to the numbers!
