GBGN1
BP Performance Transmissions LLC
- May 26, 2001
3.625 stroke-Or did the block need to be clearanced?
SignUp Now!GBGN1 said:3.625 stroke-Or did the block need to be clearanced?
Nothing aftermarket is a drop in unless it was already run and there was no problems. There is a lot of work needed for sure. The block, crank, and rods need to be looked at very carefully.When I bought the crank I swear the guy I bought it from said that this ba crank was a drop in. Boy I hope the machinist don't rape me on it.
I've done a few now with the 3.625" stroke BA crankshafts & rods, all from Dan @ DLS. None of them required any work to the block. None of them required any machining on the main/rod journals, other than some slight polishing to get the bearing clearances exactly where I wanted them. They all required rod to camshaft clearance...
If using a girdle... You will need to do some machining on it for counterweight clearance, as well as the other normal grinding that the girdle requires...
K.
Well all I can say is I hope you have better luck with your stroker crank than I had with my drop in stock stroke BA crank. I knew from the get go about the possibility of having some clearance issues but I wasn't prepared for having to turn the damn thing 10-10 as it was all over the place when we miced it out. Then after asking it if was knurled for a rear seal and was told it was good to go, I was really upset as it WASN"T knurled and the slinger on the rear of the crank had to be machined as it wouldn't even fit in the block. So needless to say after paying Kevin (my machinst here and I'll put him up against any of them) to do all the extras and a new set of 10-10 bearings I had a crank that works. For those with any wonders Kevin bought the correct knurling wheel, and made his own fixture for knurling any off these China forged cranks that are not knurled for the rear seal. I think he's had 4 or so shipped to him now to be knurled. Here's the nice job he does on the knurling. I should of just sent the damn thing back and been about $400 richer!! I will say once Kevin did all is magic on it I have had ZERO problems and now have about 6,000 miles on the engine.
