S Sam95RT/TT New Member Joined Dec 11, 2001 Nov 23, 2002 #1 I installed a K&N filter, I did damage that air intake temp sensor. Now the car backfires once in a while. Well it backfires when I gun it. Thanks
1 1badTTA Resident Smart A$$ Joined Aug 30, 2001 Nov 25, 2002 #2 check your coilpacks, I know it isn't related, but it is the most likely cause of backfiring.
R Razor Forum tech Advisor Staff member Joined Jul 31, 2001 Nov 25, 2002 #3 Ya probably damaged the hose from the filter to the turbo...any air leaks will cuase inproper MAF readings..Even a pinhole Get your scan tool out and check MAF readings..should be 6 at idle and 255 when in WOT HTH
