black magic
Black Magic
- Jun 24, 2011
any more ideas about the 02 sensor ? checked grounds all good, think it could be the chip?
SignUp Now!one lifter is worn cylinder number three about a 1/16
If the engine is grounded well enough to turn the starter it's grounded plenty well enough to ground the O2
The lobe is likely wasted. If you have the pan off you can see up through the bottom of the engine. I'd be pulling the pan anywayone lifter is worn cylinder number three about a 1/16
If you have any valve problem , bad cam , sticking valve , or broke valve springs or ect the combustion will not be right give all kind of crazy readings from the O2 , Just my OP .any insight on why o2 reading are like that??????????
...is like worrying about what shoes to go out in when you dont have any pants on
not my car friend of mine, if it was mine the motor would be out too, but he cant aford it at the moment trying to get another 50,000 out of it any insight on why o2 reading are like that??????????
...while being 100% successful playing pick up sticks with your butt cheeksYou buddy would have better odds with getting struck by lightning while winning the lottery.
