back space with baer
We have Baer 12" fronts on our 2+2 and run GTA rears in front. You can add about 1/2" more backspacing vs. the original brakes.
In the back We have a 9" granada/versailles disk rear so I can't help there.
So I could go ahead and buy the wheels with 4'' in the front and 4.25'' in the back and run spacers for the time being? Would this be too much stress on the lugs?
I would do a template check on the website.
Keep in mind BS is not the only factor in determining if the wheel will fit the brake. All wheels are created differently, so the template verifies this.
As for spacers people have different theories on them.. I believe if you use a good quality spacer you will have no problem as long as you have good studs and good stud engagement.
HTH
