Deejpig
- Aug 23, 2015
My car was running fine 95% of the time. Cold start and normal driving were fine.
The only issues I had were after it was warm, it would not start right up after shutting it off and letting it sit for a bit (1-2 hours). I'd have to crank it a few times and tap the throttle to keep it from stalling out before settling into idle, and it would run fine after getting it started.
The other issue was at WOT, it would backfire a little and sputter/miss until I let off to 75%-80% throttle. I thought it might be from running a lower octane gas. Again, it didn't seem like big deal because it ran fine during normal driving and harder acceleration - just not WOT.
Then, I got on the throttle the other day, and at WOT it made a really loud backfire sound and began to sputter and cut-out while like it was only firing on two cylinders or something. I barely made it home because while it was idling/drifting and when I gave it some throttle, it still felt like it was only firing on two cylinders. The idle seemed to level off when I got close to home, but was still a bit rough.
I started it the next morning and it fired right up and idled fine for about 3 minutes. Then the check engine light came on, it started idling rough and sputtering/missing, and eventually would shut off. I let it sit for a little, it would idle fine for a minute and then do the same thing again.
I'm in the process of getting a scanmaster, but in the meantime, after reading some other posts, it seems like it might be a bad MAF or something with the cam sensor. Below is a link to a video of what it sounds like when I start it after its warm and it starts idling rough and shuts off. I'm not touching the throttle in the video.
Any suggestions or help is appreciated! Thank you.
