Backspacing on GN,will 4.5 work?
lvega@bellsouth
I have 15x8 Centerlines with 4.5 BS & 275x60x15 DragR.,will this combo clear the framerail? Thanks for input
It should just work in a straight line with a 5/16" spacer but will rub in turns. With a 3/8" spacer (and longer studs) it will work fine.
I have 4.5" BS on my car. They fit without spacers but since the rear is never centered perfect I had one side that had very little clearance. To give me a safety margin I put a 3/8" spacer on that side and 1/4" on the other side. I have long wheel studs. I sit equal at 3/8" clearance on both sides now with 275/60 DR's.
5.5 BS on the back is fine for me.
5.5 BS on the front required cutting the inner fender plastic .
huh? 5.5?.....on what size wheel?
(anything will work with spacers.....)
