I'm rebuilding my engine......
Would .010 require new pistons also? I suppose that what, if anything gets taken out of the bores is up to them. Point is, if I need new pistons, I might as well stroke. Ideally, I'll stick with the stock pistons and standard stroke.
I recently built a relatively big dollar motor, 3.6 Porsche air cooled 6. I don't want to go down another slippery slope.
AES, Elk Grove Village IL. is the builder.
stroking it will take you down the slippery slope
The engine parts have been dropped at the shop. At first glance they dont think the bores can't remain the way they are. Likely going .020 over. So new pistons will be part of the rebuild. Short block will consist of a new GN1 Performance crank, stock rods with ARP bolts, new forged pistons...etc. cam choice is still to be determined but I'm looking for a roller cam close to stock grind.
This car came in a state of disassembly that I'm just starting to get my head around. I dont think I'm missing much but I am definitely missing the exhaust crossover pipe. It did come with two sets of headers though. I'll likely go with the stainless ones. Where can I find a crossover for them?
we have venders that will set you up with a set of headers and a down pipe that will fit with no conflict or fabrication needed that won't crack leak or burn a hole in a plastic finder.
your probably saying to yourself I don't have money burning a hole in my pocket. But trust me you will thank me after trying to fix old OE our CRAP Chinese three times.
Use the stock exh manifolds, have them welded if needed.
Use your original lifters with the stock cam in the same order they were in, if not go roller. If roller you need to cut the exh guides. Springs ect.
Is the crank internal balance? You will need a TA balancer and flex plate
AES should be fine, hopefully they have a Trq plate and V6 bob weights to balance the crank.
You really should have stuck with a stock crank, good line hone with main studs.
Can you show pictures of the spun bearing and crank?
In order to use the stock manifolds I'll need a crossover pipe, one never came with the car. That should be easy enough.
The original lifters are all out of order and border line in the trash can.
I have made no decision on cam yet. As cash allows, I'll get to that.
What would the benefit be to keeping and fixing the stock crank?
AES has the new crank, flex plate and original balancer. I'll just have to trust that they know what they're doing.
Crank.
Recommendations:
  1. Replace or abandon (do not use) the oil cooler in the radiator (metal from this failure will undoubtly be in there)
  2. Your stock cam can be reground and reused (Delta Cam has reground and parkerized many stock cams for me. This is very budget friendly)
  3. Replace the stock plastic cam thrust button with the rollerized version PIONEER 839008 (if you regrind your cam or go with a flat tappet replacement)
  4. Inspect your front cover very closely for wear. Metal will undoubtedly have caused pump damage. Rework a good front cover with minimum clearances and porting for better oiling....this is very important for engine longevity!!!
  5. Use Federal Mogul Main bearings 107M and 107M-1 to get main bearing clearance correct (I prefer .0017-.0019" on the mains)
  6. Use Clevite CB1228P rod bearings. If you're lucky you can find CB1228P-1 bearings and selectively fit
  7. Listen to Chuck.......Metal will be everywhere in that engine. CLEAN, CLEAN AND CLEAN. Or you will be doing the rebuild a second time.
Crank.
You can find a stock cross over.
If the original lifters are out of order they are junk now. toss them
Unless someone can vouch for new flat lifters, you are stuck going roller.
The benefit of the stock crank is cost. You don't need a crank at your level. You can find a STD crank fairly cheap and just polish. Line hone with studs.
They do make an external balance crank, you should know what you ordered. Its probably internal and you will need the TA balancer and flex plate. Make sure they have the v6 bob weights.
It says flexplate Neutral
This is internal balance, OE is external
you will see a chunk of steel welded and holes don't goo all the way around on the it.
Balancer is not round either
so a flex plat and balancer is needed and you engine builder will need to balance the rotating assembly
I know your on a budget but a OE rod with bolts resizing and piston fitting will be very close to new rods $
This is everything the shop is doing. I'll have a balancer ordered later today.
On the other end of the project, I have the front and rear ends removed to clean up all the parts that are in in good shape, replace the ones that aren't, lights, fillers, bezels, bumpers, header panel....etc. For an ugly car, it has good bones.
Until the GN is done, the other 6 cylinder car will have to do. But with hot months coming and no A/C, it'll probably be parked for a while too.
Very clean car,
as stated with the arp20000 bolts, just have them price rods esp with a new crank/pistons.
