Will Rhoades
 - Nov 13, 2012
I was running 22lbs of boost without any knock with Razors kit. I started to get knock and have noticed my voltage dropping. My voltage idiot light does not light up but I'm suspicious of my alternator. I got out my multimeter and checked the voltage on the battery terminals.
Voltage as follows:
@ start up idle = 14.52
With accessories = 14.24
After 30 minutes = 13.00
Alky test gain knob at 8 = 11.75
Accessories turned off = 14.27
I am under the impression that my current alternator is charging just not keeping up with my accessories. Therefore, causing my knock. This alternator was on my GN when I brought it. I believe it is a Powermaster (47806) 200Amp. Am I on the right track? Thanks in Advance.
			Voltage as follows:
