jshot
- Aug 8, 2018
ok im back at. it. new pump in. tyring to troubleshoot MV dropping to knock levels. i verified pressure is rising 1 to 1. here are some screen shots of the scanmaster readings. this is at 18psi. only thing new on this car is ta49 and 3" down pipe (plus the new fuel pump. 340 ) i also ran this at 16 psi the mv still dropped but at a slower rate. prior to mods i would run 18-19#'s with zero knock.
scanmaster is showing 2 deg KR but on my gauge was in the red...
the pull starts at 838 mv at the start of 3'rd gear. by the top of third MV has dropped to 717 . The know always start at about 730. MAF is at 255 and battery voltage is good. fuel pressue rising 1:1 (58 psi & 18lbs boost line on of course) Log shows TPS4.39 but is actually 4.6.
